ZAPTEST Supports JavaScript
- This topic has 0 replies, 1 voice, and was last updated 8 years, 7 months ago by
Home › Forums › ZAPTEST › Best Practices › ZAPTEST Supports JavaScript
ZAPTEST’s default scripting language is VBScript, but if you’re familiar with JavaScript and it benefits you to enable a more functional test upon a certain business process now you can do it in ZAPTEST:
Simply switch to JavaScript in the Test Settings -> under the Script Language section, then all your scripting in the ZAPTEST editor will use the JavaScript library, also the typed code will be in a different color then the one you type when scripting in VBScript;
While scripting in JavaScript (JS) you’ll need to follow all it’s (JS) code rules and limitations.
You can find information and learn how in the Forum -> How-To section:
