Zaptest not responding
Home Forums Ask Expert Zaptest not responding
  • #32063
      Hello Diegobacigalup!
      Are you able to scan any other app, like a chrome browser?
      Diego Bacigalup Vértiz
        Yes, I did. I made a succesful test with Outlook scanning the GUI
        #32065
          Unfortunately, we cannot replicate your issue in our lab. Could you try to create a new project and scan it again. If ZAPTEST crashes – could you check out the event viewer and provide logs?
          As we understood – “stop working” means that you cannot control the application. Could it be a popup message…? (At the background)
            I quit Zaptest and started again with a new projetct and happens the same.
            I show yesterdays event:
            1001
            4
            0
            0x80000000000000
            318076
            Application
            0
            AppHangB1
            No disponible
            0
            ZAPTEST.exe
            1.0.0.0
            5b90b98d
            35c1
            67246336
            \?C:Users*******AppDataLocalTempWER2F8B.tmp.version.xml \?C:Users********AppDataLocalTempWER2FFA.tmp.xml \?C:ProgramDataMicrosoftWindowsWERTempWER3039.tmp.WERInternalMetadata.xml WERGenerationLog.txt
            C:ProgramDataMicrosoftWindowsWERReportQueueCritical_ZAPTEST.exe_4dd71feb948e2995e082afed88eb22d73cde69d5_ca220310_cab_2e1c3076
            0
            d534d539-b2c6-11e8-944e-18dbf244b395
            96
            I put ****** on posible sensible data.
            #32067
              Thank you for the provided log, do you have another one with .NET exception?
              As an option, could you try to remove all ZAPTEST configurations? Go to: “TOOLS” -> “Options…” -> “Configurations” -> click “Remove All Configurations”. Keep in mind, you have to restore all settings later (login, passwords, etc).
