ZAPTEST is the best for Mobile test automation
Home Forums ZAPTEST Best Practices ZAPTEST is the best for Mobile test automation
  • #30946
      Using ZAPTEST you can automate any mobile application installed on a mobile device;
      You can then run the same test on any mobile device operating system type (iOS, Android, etc.), we call this approach Cross Platform – To do this you can use one (Or both) of the following options:
      – Physically connect your device to the machine which will be executing your test, using the ZAP Viewer you’ll be able to run the device’s app and execute the testing script upon it.
      – Another option is to use ZAP’s most recommended device management application ZAPFARM:
      This is a true mobile (and other machines’ type) farm which can be viewed under the same page – The ZAPFARM Dashboard enables you to connect simultaneously to multiple mobile devices (even different types of devices). For example, you can run a single mobile based automated test upon all devices as follow:
      Connect all required devices and specify them all in ZAPFARM, once you complete this in ZAPTEST open the testing script and go to M-RUN, access ZAPFARM and you will be able to view all connected devices and run your test on all devices simultaneously.
      You can find information and learn how in the Forum -> How-To section (You can also find help for both mentioned apps, for ZAPTEST and for ZAPFARM):
