Zaptest is recognizing two entry fields as one
Home Forums Ask Expert Zaptest is recognizing two entry fields as one
  • #32069
      Hello david.michienzi. Thanks for using ZAPTEST
      You can do it manually as in your case these entry fields are hard to recognize separately.
      The best way is to create 2 image object for the login and password icons and then create 2 related entry fields for the input text.
      You can watch following tutorial video to make it clear if you have some misunderstandings:
      Building Your First Script
