Zaptest doesnot recognises textbox field
Home Forums Ask Expert Zaptest doesnot recognises textbox field
  • #31542
    LN Jena
      Zaptest doesnot recognises textbox field even in zaptest demo application
        Hello jena.lnarayan,
        In order to create an object for the textbox field you need to specify different properties to the object then the ones you currently have:
        1. The textbox field does not contain any caption in it, so its “Recognition Type” property have to be set as “Image”.
        2. Because the object is now set as Image you have to set for it the “Relative Object” property which will be the closes object that ZAPTEST can recognize (Meaning, an object with a caption in it).
        Please download the demo test “Login.zap” (The first download at the https://www.zaptest.com/tutorial page) and see example testing script.
        LN Jena
          why this step has not been added in video tutorial.why doesnot script recognises objects even if we foolowed the same way as demonstrated in video
          #31547
            Please check the following Tutorial page which have number of videos explaining how to start working with ZAPTEST:
            Next to some of the videos you will find examples of tests you can download which the videos refer to.
            Regarding the object’s recognition issue, please send a screenshot of the object’s properties you have set.
