ZAPTEST can encrypt data
- This topic has 0 replies, 1 voice, and was last updated 8 years, 8 months ago by
Home › Forums › ZAPTEST › Best Practices › ZAPTEST can encrypt data
With ZAPTEST you can encrypt data in the test you do not want to be viewed by others:
Using the “Encrypt Text” feature you can encrypt any given string and use it, in its true form, in the application you are testing ;
For example, you can encrypt passwords in the testing script and during runtime the encrypted password will be turned into its true form.
