ZAPTEST advanced searching feature
- This topic has 0 replies, 1 voice, and was last updated 8 years, 8 months ago by
Home › Forums › ZAPTEST › Best Practices › ZAPTEST advanced searching feature
The ZAPTEST Search Utility feature allows you to search your entire drives for tests using any required keyword;
All the tests then gather to the search results window and from it you can open any test for your needs.
