ZAP-fiX: One Script Solution!
Home Forums ZAPTEST Old Posts ZAP-fiX: One Script Solution!
  • #30429
    Curtis Don
      Hello! How can I make same Zap-Fix script work for both Zap-Fix Mac Viewer and a regular browser in Windows (assuming I’m accessing same web application via Firefox on Mac)?
      #30430
        Hello Curtis,
        Thank you for posting your question.
        To make your script work, you need to include regular expression for parent AUT object in Object Repository, to enable QTP recognize either AUT window.
        – Locate Window object which represents AUT.
        – Put regular expression in its "regexpwndtitle" property:
        if the current "regexpwndtitle" property is set to "Mac Viewer" then replace it with something like this: "(Mac Viewer)|(Firefox)" (where "Firefox" stands for whatever regexpwndtitle is on the Firefox on Windows).
        Sergey
