ZAP-fiX Instrumenter
- This topic has 0 replies, 1 voice, and was last updated 12 years, 3 months ago by
ZAP Technologies.
ZAP Instrumenter is an add-in for iOS and Android for ZAP-fiX software. Instrumenter allow user to avoid rooting (jailbreaking) of Device Under Test (DUT) by instrumenting Application Under Test (AUT) with ZAP Mobile Framework library. After instrumentation user can use ZAP Mobile Viewer in the same way as they are using with the ZAP default (rooted) DUT configuration. Scripts developed with rooted and/or instrumented approach are interchangeable.
[youtube:94tlz0u1]5ER8kCekiMI[/youtube:94tlz0u1]
