Zap-fix freeze after some use
- This topic has 1 reply, 2 voices, and was last updated 10 years, 8 months ago by
Basically this issue we had reports from another client of ours, but non of our other clients experienced such issue, therefore we tend to believe this issue is being caused by problematic environment (Unsupported orand contains elements which conflict with Zap-fix).
To understand more precisely what the problem is we need to install 2 components where the problematic Zap-fix instance is being installed:
1. Zap-fix Debug agent, which will allow remote debugging of Zap-fix instance.
2. Hamatchi VPN, to enable access to the specific machine from remote.
With these 2 components our R&D team will be able to access remotely to the problematic Zap-fix instance and isolate its issues.
Sasha.
