Zap Browser 1.16 fails to connect to iOS 10.3.1
Home Forums Ask Expert Zap Browser 1.16 fails to connect to iOS 10.3.1
  • This topic has 4 replies, 2 voices, and was last updated 8 years ago by Aaron Mauchley.
  • #31062
      Good morning, Aaron Mauchley!
      Unfortunately, Apple could block launching process on iPad iOS 10.3.1 when you are using Enterprise or Release version of certificates. You could try reboot your device: but some times later you could get this problem again.
      To avoid this problem you should reinstall ZAP Browser (or any other application) using Debug (Development) version of certificate and provision file.
      Aaron Mauchley
        Andrey:
        I’ll try rebooting, in the meantime, when you say to using the “Debug (Development)” versions of the certificate and provision file for ZAP Browser, as far as I know there isn’t any? When you download the ZAP Browser from the ZapTest.com Downloads page (v1.16) it only comes with the .ipa since the Agent is included in it already, am I missing something or not pulling down the correct download?
        #31064
          IPA package on our website is signed using Enterprise certificate. We cannot sign it using Development version because Development version should have information about your phone (ID). To generate Development certificate you should enrol to Apple Development Program. Usually RnD team has all information about Development certificate and provision files.
          Aaron Mauchley
            Alright, thank you, I’m new to iOS development so I appreciate the answer and clarification.
