Why Zap mobile testing is better then other companies?
Home Forums ZAPTEST Old Posts Why Zap mobile testing is better then other companies?
  • #30434
      These are the main reasons why Zap, its services and its products are the best choice for you:
      1. Zap is one of the top market leaders in QA services, and now Zap is one of HP’s elite Partners;
      Also Zap is an elite Partner of Apple and other companies (Check the following list of companies which partner with Zap at http://www.zaptechnologies.com/index.php/why-us/partners).
      This means Zap has recognition of the 2 biggest IT companies in the world, which guaranties Zap’s services and its products highest quality.
      2. Zap’s solution for mobile testing, the Zap-fix feature, designed in such way to enable any UI mobile testing in every known mobile device and in any future published mobile device – This means the ZPX (Zap-fix) is the ultimate solution for mobile testing (This is the only mobile testing solution which can integrate with every mobile device).
      3. ZPX is fully integrated with HP’s QA applications (QuickTest, LoadRunner, Quality-Center, etc), this means you can work with the best testing tools in the market for your mobile testing.
      4. ZPX is the only testing solution enabling such testing options as:
      – Cross-platform testing (You can test several types of platforms in a single test).
      – 1 script solution (Enables you to create generic testing scripts which will work on any other platform).
      – ZPX is the only solution which can work and test any type of OS (Unix, Mac, Windows, IOS, Android, and more).
      5. Zap offers its own services to create tests, and maintain them for any environment and need.
      There are many more features and services you can get from Zap including from ZPX, please contact Zap for more details at http://www.zaptechnologies.com/contact-us.
