Why Zap-fix does not scan all objects in a GUI?
Home Forums ZAPTEST Old Posts Why Zap-fix does not scan all objects in a GUI?
  • #30516
      Because of the revolutionary ZPX (Zap-fix) technology, which allows creating automated tests on any known GUI based application (Tests that can be executed in all known platforms without changing them), ZPX is not an ordinary testing tool:
      It uses most original and patent based engine which is unique only for ZPX.
      Although ZPX UI looks similar to other known testing applications’ UI, it still varied significantly from other known testing tools (And much more advanced).
      When ZPX (Zap-fix) scans a GUI, ZPX captures it in a certain unique way which may not all GUI objects will be added to the Objects’ list:
      Therefore if in the tested app there were objects which did not add automatically to the ZPX Workbench objects’ list, it will require adding them manually (By clicking the Add Object button).
