What is ZAPTEST?
- This topic has 0 replies, 1 voice, and was last updated 10 years, 3 months ago by
Home › Forums › ZAPTEST › Best Practices › What is ZAPTEST?
ZAPTEST is a New Generation software test automation solution for testing applications Cross-Platform. ZAPTEST allows testing of any GUI based software on any modern OS, mobile or conventional including iOS; Android; WinMo; Blackberry; Windows; Mac; and Linux, and supports testing of Agile and CI (DevOps) development. ZAP’s main technologies are ZAPTEST and ZAPFARM.
Main principal of ZAPTEST is non-intrusive test automation through application GUI mimicking end-user action. We say at ZAP, “ If you can test it manually, ZAPTEST can automate it!”.
ZAPTEST is using ZAP Object Engine technology based on the visual object recognition that includes combination of OCR + Edge Detection + Image recognition. ZOE algorithm is the foundation of ZAPTEST 1Scritp’s GUI Map and Workbench. Using ZOE 1Script tests can execute on any permutation of AUT in any test environment and OS.
ZAPTEST has Free and Enterprise editions allowing users to perform test automation and execution Fast!
ZAPTEST test automation process is based on 3 phases: Script > Document > Execute
During the Scripting phase testers create 1 Script per 1 Business process of ANY Software GUI based application on any supported OS. Document phase allows testers to auto-generate test documentation from 1Script, and therefore eliminates the need for developing and maintaining documentation separately. Execution of ZAPTEST scripts can be done either traditional way from 1Script module or in M-RUN in parallel on ALL test environments at once.
ZAPTEST is the ultimate technology for modern test automation allowing testers to streamline the test automation process and to deliver testing Just-in-Time!
