What is the syntax for ALT+TAB key
Home Forums Ask Expert What is the syntax for ALT+TAB key
  • #32795
    Mamatha Shivaprasad
      #32796
        Hello mamatha.shivaprasad,
        In order to execute keyboard actions properly it is important first to make sure, during the running of the test, that the focus will be on the window you wish to execute the keyboard commands upon it – You can use similar command as the following one (Make sure to specify your exact objects in it instead of what I’ve wrote):
        Application(“Application name”).View(“View name”).Object(“Some Object name”).Exist
        And these are the commands to execute the keyboard actions you’ve asked:
        ZAP.Keyboard.KeyDown ZAP.Keys.AltLeft
        ZAP.Keyboard.KeyPress ZAP.Keys.Tab
        ZAP.Keyboard.KeyUp ZAP.Keys.AltLeft
        Hope this makes sense.
