What is new in Zap-fix?
Home Forums ZAPTEST Old Posts What is new in Zap-fix?
  • #30596
      Please check the following new features both in the Zap-fix Standalone version and in the Zap-fix Add-in for UFT:
      Zap-fix Standalone version:
      • Step view has parametirzation
      • Step view supports multiple parameters and hidden attributes for methods
      • Better design for Step view
      • DigiCert certificate authentication added to all executables. All products should have ZAP Technologies International, Inc signature
      • GUI Step View
      • Recording – Test Case Recording is now available.
      • While recording the user can enable Image Only mode by clicking the "Image Only" button in the recorder toolbar or double clicking Control key on the keyboard. This mode will disable OCR object recognition and will only add objects using Images for the objects that were recorded when the mode was on.
      Zap-fix UFT Add-in version:
      • UFT 12.01 Support
      • Image Recognition
      • French Language OCR improved stability
      Also in both Zap-fix the Standalone and the UFT Add-in versions numerous of serious bugs and issues were fixed.
      Please contact Zap for further help and information.
