What are the latest features in Zap-fix?
- This topic has 1 reply, 2 voices, and was last updated 10 years, 8 months ago by
Basically it is very important to upgrade Zap-fix to its latest version because each version will be more robust and will work much better then the the previous versions.
Also, in the latest version you’ll have features such as:
Multirun – Enables Zap-fix to run upon number of remote connected devices;
In the latest versions this feature was upgraded significantly, enabling more flexible execution of Zap-fix tests.
– Capture any required screenshot into Zap-fix final test results.
– Adding more methods into Zap-fix Standalone version.
– Adding new type of object class named Swiper.
– Enabling Shared Object Repository (Even in a remote directory).
– Fixing numerous of bugs.
– And a lot more.
Please contact Zap for further advise and help.
