Wait and thread sleep
Home Forums Ask Expert Wait and thread sleep
  • #31348
      Hello Aqu, thanks for your question
      You can use either wait statement (e.g. Wait 5 – to wait 5 seconds), or you can use Exist method for the object you are expecting. By default “Exist” has 45 seconds timeout for object recognition. This value specified in TOOLS – Options – Runtime – Global Timeout. You can set any value whatever you may need – up to 9223372036854775807 milliseconds.
      Also you can specify Exist timeout in the method parameters within script – see screenshot attached.
        Hello Aqu
        I post an answer to your question in the old thread not to make bunch of copies of similar topics.
        Just as example – Wait statement will look following
        Application(“Application”).View(“View 4”).Object(“User Name”).Type (“expawq”)
        Application(“Application”).View(“View 4”).Object(“Image Object 6”).Click
        Application(“Application”).View(“View 4”).Object(“Image Object 6”).Type (“August2017”)
        Application(“Application”).View(“View 4”).Object(“Log On”).Click
        Wait 5
        Application(“Application”).View(“View 5”).Object(“BILKA TILST…”).Click
        Thus ZAPTEST will wait 5 seconds before trying to click object “BILKA TILST”
