Validation Problem
Validation Problem
Home Forums Ask Expert Validation Problem
  • #31491
    Asif Qureshi
      Hi ZAPTEST TEAM,
      I facing one problem. i wrote the scripts when successful message is not found then else case should be run but in that it did not go to else part. See Below Code:
      ‘Case 1: Invalid Username is provided (Both field are empty)
      Application(“Log_on”).View(“View”).Object(“Log On”).Click
      If Application(“Invalid_UserName”).View(“View”).Object(“Invalid username is provided.”).Exist then
      Application(“Invalid_UserName”).View(“View”).CustomReport True,”Invalid username is provided.”,”Message is appeared Successfully”, True
      Application(“Invalid_UserName”).View(“View”).Object(“OK”).Click
      Application(“Log_on”).View(“View”).Object(“User Name”).Type Datatable.Value(“UserName”)
      Else
      Application(“Invalid_UserName”).CustomReport Error,”Invalid username is provided”,”Wrong Message”,True
      End If
      Regards,
      AQU
      #31492
        Hello Aqu
        I believe this line is incorrect
        Use “False” instead of “Error”.
        ZAPTEST team
        #31493
        Asif Qureshi
          Hi ZAPTEST TEAM,
          Problem is still exist.
          See Attached Image.
          Regards,
          AQU
          #31494
            The problem is that the object not exist.
            Looks like it is relative object and you need to update code with parent object name.
            Hope that helps,
