Validate (Assert) numerical data from rest request
Home Forums Ask Expert Validate (Assert) numerical data from rest request
  • #32350
      Hello Alan!
      Fo non-scripted mode you can use write a “Regular Expression” to validate number (less/equal). To use Regular Expressions in ZAPTEST method, don’t forget to enable “Use RegExps” method property.
      Current SCRIPT-LESS version doesn’t have an alternative way to compare number.
        Hello Alan!
        PS. You can use If/Else conditions for comparing some specific results. Please refer to Script-Less tutorials, how to write such script and use variables in Script-Less mode.
        Alan Carr
          Hi
          I’m confused, I’m using step view with reg exp true.
          I have my “check list” how do I enter into the check list my conditions for numeric data
          p.s What is the difference between SCRIPT-LESS and non scripted are they not the same ?
          #32353
            Hello Alan!
            Yes, Script-Less and Non-Scripted sentences have the same meaning.
            For checking value you could write a simple regular expression, where:
            d - numbers 0-9
            1d - numbers 10-19
            2[0-5] - numbers 20-25
            (x|y|z) - one of x, y or z
            So, in your case, you can accept only 0, 1, 2, 3, 4, 5 numbers, which is “[0-5]“.
