Using wildcards in validation
Home Forums Ask Expert Using wildcards in validation
  • #31636
    Ken Hopper
      I am trying to determine if wildcards can be used in text validation? For example, I have a file that is created daily with the same name but the date added at the end of the filename each time it is run. I would like to be able to validate that the file exists but the test will fail if the filename changes due to the date in the filename changing each time I run it.
      Thanks!
      #31637
        Hello kenh,
        You definitely can use a wildcard in ZAPTEST:
        To use a wildcard you add the file name as an object and specify its “Text” property as, for example, “Test_2.*”, ZAPTEST will then locate the file which has the prefix “Test_2”.
        But based on your description I believe the best solution is not to use a wildcard because, for example, if there are several of such files with the same prefix in the same directory ZAPTEST may located a different file instead of the specific one;
        In such case (Where there is a chance to have several of such files) I would recommend to generate the file’s name, for example, if the file’s name is “Test_2162018.xls” use this code to generate the file’s name, update the “Text” property and check if the file exists:
        strDate = Date
        strDate = Replace(strDate, “/”, “”)
        strFilename = “Test_” & strDate & “.xls”
        Application(“Application”).View(“View”).Object(“File Name”).SetProperty “Text”, strFilename
        If Application(“Application”).View(“View”).Object(“File Name”).Exist Then
        Application(“Application”).CustomReport True, “File Exists”, “File exists.”, True
        Else
        Application(“Application”).CustomReport False, “File does not Exist”, “File does not exist.”, True
        End If
