UNREAL dropdown menu problem
Home Forums Ask Expert UNREAL dropdown menu problem
  • #32014
      Hello scum4you,
      Please check the following tutorial video to help you with the drop-down menus:
      Lists and Tables
      If you wish the test will directly select already a know value into the drop-down without open it and scroll for data you can use the following workaround (To understand each method’s attributes you can see its tooltips right after you select it):
      Application(“Application”).View(“View”).Object(“Object Name”). Type “Value you wish to select{ENTER}”, 1, False
      For more help on using ZAPTEST please refer to our Beginner Tutorial at:
      Also you can check our extensive videos’ documentation at:
      Ju Ki
        Thank you for your help I will try it out directly hopefully it will help but thx a lot already 🙂
