Unable to type into text box embedded
Home Forums Ask Expert Unable to type into text box embedded
  • #32661
      Hello cpinnock,
      There may be different reasons why the required text-box cannot be detected, here are some of the reasons:
      1. The parent object (“lblCourseCatalog”) is not being detected properly, this also may be due to different possible reasons:Make sure the object is being detected successfully in the ZAPTEST GUI Map, if it does run the following command:
      Application(“Ascriptica”).View(“Catalog”).Object(“lblCourseCatalog”).Exist
      Then check the final test’s results to check if the command passed successfully and the “lblCourseCatalog” was located successfully.
      2. The “txtSearch” object’s borders were not set properly:In some cases the borders may be in such position which ZAPTEST will have difficulties to type a text in it (Or will locate the text-box differently then what is expected):
      You need to change the borders in the ZAPTEST GUI Map which will include the text-box properly (Do a few runs of the command after each change to check if the borders were set properly).
      3. The parent object “lblCourseCatalog” is a dynamic object which appears after certain action orand the “txtSearch” object has dynamic size that changes according to other appeared text-boxes.
      If the above did not help please attach a full page screenshot + the test itself (The *.zap file) so we can check the issue more precisely.
      Also you can refer to our free online ZAPTEST Beginner Tutorial for further help:
      And to our free online Documentation:
