Transfering project folder
Home Forums Ask Expert Transfering project folder
  • #32463
      Hello arulraj.dhinakararajan. Thanks for using ZAPTEST.
      The *.zap file includes everything that you need unless you manually select some external repository/functional library/etc (I guess you don’t), and everything that you need is just install ZAPTEST to another machine and transfer script there.
      Kirill,
