Hello savita_kolhe,
Please do the following:
Update the “regexpwndtitle” property of the “Application” object to the new title of your AUT (Application Under Test):
If this will not work then remove the entire string in the “regexpwndtitle” property, then if you do not use the method “Launch” then make sure to close all other opened windows except the AUT and ZAPTEST and run your test again (If you do use the method “Launch” then close all windows except ZAPTEST and run the test again).
If this will not work please attach your script and a screenshot of the AUT view the test is failing upon and we’ll continue researching this issue.
