The Multirun does not work
Home Forums ZAPTEST Old Posts The Multirun does not work
  • #30591
    Alisha Michaels
      When we try to run an automated test using the Multirun nothing works:
      We see the application we want to test (After connecting to it via Multirun) but when we click the Run button the test is not being executed upon the application.
      Please help.
        Hello AlishaM,
        Basically when you want to work with the ZPX (Zap-fix) Multirun feature, all the required functionality to connect to an extrnal device, and =run the test upon it are in the Multirun window itself.
        These are the steps t work with Multirun:
        1. Open a testing script using the regular Open feature in ZPX.
        2. Click on the Multirun toolbar icon to open the ZPX Multirun feature.
        3. Click on the Add Device icon in the Multirun to add a new devise (To be able to create a file which teh ZPX will be able to open you need first to open the specific device using the ZPX Viewer feature, then save the opened view as a *.zpd file)
        4. Click the Connect icon in the Multirun and notice if the small lightning icon changes into the Disconnect All icon
        5. Use the right small arrow to select the Run feature and select if you want to run in a sequential way or parallel way (in case you have multiple devices connected and you wish to run the testing script on all the devices – This feature requires a special license).
        Hope this helped.
        Please connect to Zap for further help.
