server connection
- This topic has 1 reply, 2 voices, and was last updated 1 year, 9 months ago by
Home › Forums › Ask Expert › server connection
Hello Moha Modi,
To get more help and understanding how to use ZAPTEST you can explore ZAP portal, in it there are pages such as:
– Beginner Tutorial at:
– Webinars:
– Documentation:
Regarding your question, ZAPTEST does support running tests on remote devices:
– This Webinar explains how to run test on a remote machine:
– This Webinar explains how to use the ZAPFARM which you nee to connect remote devices for using with ZAPTEST:
– If you wish to run a test automatically in certain scheduled period of time, you can set a batch file using ZAPTEST command prompt commands, such as the following:
And add this batch file to a scheduled execution app such as MS Task Scheduler.
If you wish to run a test which its testing script will be located in a remote machine, you’ll need to make sure there is a free access to this machine so ZAPTEST will be able to open the test without any network difficulties.
Hope the above helps.
