Scroll 3 times
- This topic has 1 reply, 2 voices, and was last updated 3 years, 7 months ago by
Sergey ZAP.
Home › Forums › Ask Expert › Scroll 3 times
I have created an Object inside the Scroll bar and trying to click 3 times so the Scroll bar comes all the way down, but for some reason its clicks only once and doesn’t click again. Is there any solution to scroll down?
Hello Adil!
It’s possible that your scroll bar object may change after first scroll, and ZAPTEST no longer can find it (you should see corresponding errors in Results). Use a relative object for a scroll bar instead.
