Script selecting the wrong object
- This topic has 1 reply, 2 voices, and was last updated 6 years ago by
Home › Forums › Ask Expert › Script selecting the wrong object
Hello sridhar5.ms,
Please do the following:
1. In each of the objects’ Properties there is a Property named “Appearance”, if you have multiple similar objects you will need to set this Property to “By Order” and when you’ll do it a number will appear instead, this number is an index number (If there are more then 1 similar objects in a UI ZAPTEST numerates these objects and has a specific index number to each one of these objects).
2. Now if ZAPTEST still does not recognize (Finds) the Dropdown you are interested in you need to specify a different index number and continue with this update until the specific object will be found.
Please check also the following “How-To” video for more visual explanation:
https://www.zaptest.com/user-zone/product-training/zaptest/properties/appearance-property
