Script is running very slow using firefox
Home Forums Ask Expert Script is running very slow using firefox
Viewing 8 posts - 1 through 8 (of 8 total)
  • #31612
    Ramakrishna Jarubula
      Hi All,
      Script is running very slow using Firefox browser. Any solution for this issue?
      Also observed objects identified using chrome is not properly working in Firefox.
      Thanks & Regards,
      Ramakrishna
      #31613
        Hello Ramakrishna. Thanks for using ZAPTEST
        Most of the times problem with slow script running is due object recognition problem. In the script results do you have all the steps successful?
        Are you using ZAPTEST for some internal web-interface or with some globbal website? Can you attach script and we will look into it and see what may be wrong?
          Hi Team,
          Thank you very much for your quick response.
          Means objects reorganization for chrome and Firefox are different using ZAPTEST? Do i need to create different scripts for different browsers?
          I am using it for my internal website.
          Below is the script which i have written.
          Application(“Kalam”).Launch Datatable.Value(“Browser”),url
          Application(“Kalam”).View(“Login”).Object(“CAPITA”).Exist
          Application(“Kalam”).View(“Login”).Object(“Employee benefits”).Exist
          Application(“Kalam”).View(“Login”).Object(“Username”).Type “vale”
          Application(“Kalam”).View(“Login”).Object(“Password”).Type “Value”
          Application(“Kalam”).View(“Login”).Object(“LoginBtn”).Click
          Application(“Kalam”).View(“HomePage”).Object(“Orbit Administrator Home”).Exist
          #31615
            Ramakrishna
            Basically you do not need another script for different browsers. Most of the times it is OK for running multi-environmental.
            As for script text you post above – it looks OK but there ara some fine-tuning things (property change etc) that may be important. So if you are able to attch script file it will be more efficient for troubleshooting.
              Also script is very slow using Firefox. This issue also because of Object recognition?
              #31619
                Ramakrishna
                That may be the case. For deeper investigation we need to see script file.
                  Please find the attached scripts for your reference.
                  #31621
                    I guess problem may be related to “login” and “password” textboxes.
                    Can you try updated script (attached) and provide feedback.
