Script is run on other machine
- This topic has 1 reply, 2 voices, and was last updated 7 years, 6 months ago by
Home › Forums › Ask Expert › Script is run on other machine
Hello aqu,
Yes, this is one of the great advantages of the ZAPTEST that you can run its tests in different platformsenvironments.
Basically you just need to save the script in any accessible directory and send the test’s file to your colleague, and then they can execute it in their end – There are only 2 main limitations you have to take into considaration:
1. The other county’s GUI have to be the same as your GUI (As the GUI which you’ve automated the test upon), if there is some different objects (Such as different captions) it is important to update these objects’ properties so ZAPTEST will be able to recognize them (If there are pages of the other county which are different and require to be automated as well, there is a need to scan these pages and update the test with the new scanned pages accordingly).
2. Each person who wishes to execute ZAPTEST based tests must have a ZAPTEST instance installed in the machine the test supposes to be executed from.
Hope this makes sense.
