Script contents are not displayed all of a sudden.
Home Forums Ask Expert Script contents are not displayed all of a sudden.
  • #31960
      Hello ajay.sathyanarayana,
      This may be because of the following reasons:
      1. There may be a problem with your system requirements (Such as with the NET Framework version) – These are the recommended system requirements for ZAPTEST, please make sure your machine is compatible with ZAPTEST:
      OS: Windows 7 or higher
      Processor: 1 gigahertz (GHz) or faster
      RAM: 1 GB (32-bit) or 2 GB (64-bit)
      Hard disk space: 1.5 GB
      Libraries: .Net Framework 4.7.1
      2. After installing ZAPTEST, some machines need to be restarted – Please restart your machine and try again:
      If this will not help, uninstall ZAPTEST, delete all its directories, install again ZAPTEST and restart the machine.
      3. If you create a test in Script view and then you click on Step view all the testing script in Script view will be deleted – This is because the Step view is a separate option to create test which is not related to the Script view.
      Diego Bacigalup Vértiz
        Are you planning to relate both? It would be very useful. Some times works correctly, and sometimes it’s all gone.
        #32051
          Hello Diegobacigalup!
          Single project can be only in “Scripted” (Script tab) or “Script-Less” (Step tab) mode. But script by script you could combine the logic: “login.zap” could be scripted and “fill_form.zap” could be script-less.
          There is no planned option to combine both type in a single script: Enterprise edition has ability to use master script which can call child scripts (scripted or script-less).
          Let us know, if you still have a questions.
          hay ho
            I thought there was an auto-save option. If there isn’t, can you add one? You may loose a few hours of work with a bad click! Besides, when the script starts, it should ask or auto-save.
            #32085
              Hey otehrani_2003
              ZAPTEST has auto-save for sure
              You can adjust auto-save frequency – proceed to Tools – Options – Auto Saving. Also link to the auto-saved projects folder presented here.
