Scheduler in Zaptest
Home Forums Ask Expert Scheduler in Zaptest
Viewing 15 posts - 1 through 15 (of 17 total)
  • #31981
    Abhishek P
      Hi Team,
      Does Zaptest provide any functionality to schedule the test execution e.g. every 30 mins ?
      Also does it provide the mailing functinality for the reports ?
      Abhishek
      #31984
        Hello Abhishek. Thanks for using ZAPTEST
        For scheduled execution you can use Windows Task Scheduler.
        First you need to create batch file for ZAP script execution (see link). Then schedule this batch execution with Windows Task Scheduler.
        Abhishek P
          Thanks for the help.
          Another question is, Can we consolidate/merge the test execution reports to generate a summary report of every test execution?
          #31986
            Hello Abhishek
            In Enterprise edition it is possible to create modular script which one will call for external scripts and execute it one by one. Then in report all the results will be presented. In Free edition this feature unavailable though.
            Abhishek P
              Can we customize the reports or parse them?
              #31988
              Abhishek P
                OR
                Export the report data to excel/CSV
                #31989
                  Abhishek, you can parse the result files as it based on xml. Customization is not available.
                  Abhishek P
                    Can you please help me in identifying dynamic objects through zaptest, object test value is changing every 5 min
                    thanks,
                    abhishek
                    #31997
                      Hi Abhishek
                      There are numbers of solutions – parametrization of text values of the objects (if these objects are OCR type), use external tables for the object names/text, write some specific functions that snaps up the object and compare it to the different one. These features available for Enterprise edition. This kind of testing is advanced testing already thus we are suggesting to upgrade to Enterprise license.
                      For Free edition the only solution I can propose is to get entire amount of possible objects in repository and use if-else for validation it one by one.
                      Abhishek P
                        Does ZAPTEST trial version works for desktop based applications also or only web based applications ?
                        #31999
                          It works for any application GUI.
                          Abhishek P
                            I am trying to launch an application from desktop icon, not working
                            when trying to launch through file path (application file not exe file), path not found error
                            Not sure where is the problem ?
                            #32001
                              Are you using Step or Scripted workflow?
                              #32002
                              Abhishek P
                                trying both;
                                ‘Application(“Application”).View(“View”).Object(“111 AppUndertest”).DblClick — (icon using recording)
                                ‘Application(“Application”).Launch “C:Program Files (x86)testAppUndertestAppUndertest.Report” — (application file path using script)
                                #32021
                                Abhishek P
                                  Hi Team,
                                  Does ZAPTEST trial version identifies excel objects e.g.
                                  Menu options – File, Home
                                  ‘Close’ button
