scan GUI through workbench
Home Forums Ask Expert scan GUI through workbench
  • #31214
      Hello nikita,
      Please explain what do you mean that the view did not scan properly?
      Please explain what did you expect to scan and what is the result.
      What do I need to expect seeing in the screenshot?
        Guys, sorry that I am step in to your dialog but first of all – Nikita, I can see you are probably using quite old version of ZAPTEST. Current version primarily uses GUI Map application scanning with significantly improved recognition. If you are using some old version of ZAPTEST please download latest version of ZAPTEST – https://www.zaptest.com/user-zone/downloads and try to use GUI Map for application scanning. I believe it may resolve your issues.
        Thank you.
