Radio Buttons and Check boxes
Home Forums Ask Expert Radio Buttons and Check boxes
  • #31514
    Bruce Spring
      How does one determine whether a Radio Button or Check Box is Checked or not checked? I’m assuming it is considered an Image Object and not one of the OCR objects.
        Hello bruce.spring,
        Basically you can do it as follow:
        1. Using the ZAPTEST GUI Map scan the page with the Radio-buttonCheckbox in both situations (Create 2 saved Views):
        One when the Radio-buttonCheckbox is checked and the other when it is unchecked.
        2. In both scanned pages set the image based object rectangle inside the Radio-buttonCheckbox (By enlarging the scanned GUI image in the GUI Map).
        3. Using the “GetAverageColorName” method find the color inside the object.
        4. Using a condition statement check if the Radio-buttonCheckbox object has a different color then White:
        If it is different then White the Radio-buttonCheckbox is checked and if it is White then it is unchecked
        Hope this makes sense.
        Happy Thanksgiving Day.
