Problems to locate objects
Home Forums ZAPTEST Old Posts Problems to locate objects
  • #30466
      Hello RobKites,
      There is a known bug in the QTP api toolkit that can create unstable object recognition.
      This commonly occurs when the application is in full screen mode.
      It is highly advised not to work in a full screen mode and in standard text display to prevent any issue.
