Problem in Using Function
Home Forums Ask Expert Problem in Using Function
  • #31337
      Hello, thanks for using ZAPTEST
      Your function looks OK but I cannot see call for a function. Did you place entire code to the message?
      In this case you simply not inserted it to the code?
      abhinav kumar
        Can you please modify the code and post it, showing how to call the function in Zaptest.
