Parse partial data for check list
Home Forums Ask Expert Parse partial data for check list
  • This topic has 1 reply, 2 voices, and was last updated 6 years ago by Valentin ZAP.
  • #32283
      Hello Alan!
      1. If you would like to check the only portion of your returned data, you could use a regular expression there, but to enable them you should update object properly value: “Use RExpseg” -> True. Then you could set checklist value as “AAA”, “BBB” or use any other valid regular expression.
      2. Yes, you should use multiple items in your checklist. We could access any member of the complex object by path, where for arrays we should use the brackets “[0]”, example: “Data[0].Name”
      PS. Also, you could use helper object methods to get all or part data and do all check in the script (for advanced case): see .GetMemberResponse method
      PPS. If you get any troubles with paths, please let us know.
      Let us know if you still have any questions.
