Object Properties
Object Properties
Home Forums ZAPTEST Old Posts Object Properties
  • #30602
      To view the properties of an object, you need to select the object in the Repository Explorer first.
      Different object types have different sets of properties.
      An application object has its window title and flag for Mobile Viewer.
      An object of View class has its unique View ID. The displayed image is captured when the GUI was last scanned and it serves for informational purpose only.
      A regular object of OCR Recognition type has more properties, and all of them are used during object recognition.
      It’s possible to modify Text and Text Precision properties here. However, other properties must be modified using the Workbench.
      The relative object of OCR Recognition type uses only coordinates to identify its position relative to the parent object. Please use the Workbench if you need to modify its position.
      The regular object of Image Recognition type uses only its image for identification, all other properties are irrelevant.
      For user convenience, the Properties window can be easily re-sized, detached, or re-positioned.
      Hope this helped.
