Not able to identify link from the full texr
Home Forums Ask Expert Not able to identify link from the full texr
  • #31625
    Ramakrishna Jarubula
      Hi Team,
      We are having a trouble to identify link from the full text. From the below ex, I need to click “Register Now!”. Scan is not identifying the object.
      Ex: Haven’t got account?, Register Now!.
        Hi Ramakrishna. Thanks for using ZAPTEST.
        Note that “Register Now!” is a part of the long string. Default recognition type for text is “OCR (Single)” which recognize the whole string. To recognize part of the string please use “OCR (Partial)” recognition type in Object Properties.
          When we are scanning the objects, ZAPTEST is recognizing the “Haven’t got account?, Register Now!.”. If ZAPTEST identify, then i can change the properties. Kindly help me with the solution.
          Regards,
          Ramakrishna
          #31635
            Hi Ramakrishna
            You need to change properties of the object “Haven’t got account?, Register Now!.”. Go to Object properties, change “Text” to “Register Now!” (you also may need to change name of the object accordingly) and change recognition type to “OCR (Partial)”.
            See screenshot attached.
            Then your object will be recognized as part of the string.
