My Repository items are dissapearing???
Home Forums Ask Expert My Repository items are dissapearing???
  • #31036
    Casey Brannon
      Been using Free Version 16.2.12 on Windows 10.
      After several days of work; I just finished a very long script (350ish lines of code) that I went to run in completion (had only been spot testing the code – and it all worked).
      Now I’ve found several instances where random Application, View, and Objects that I build the script with are just… gone.
      I save frequently. I did have some Workbench issues/errors, but I always just redid what I was working on and then generated and tested code. I almost always drag and drop from the GUI Map tab to generate code so I know the items were there at one point.
      I just updated to version 16.2.14.
      Any way I can generate some diagnostic logs to send in if this happens again?
      #31037
        Hey cbrannon,
        I wonder whats causing this. I remember having similar issue awhile back but it was fixed somewhere in the 6.1.5 version. I wonder if the same issue remained but in more of rare cases.
        Please if you notice this again, try to see the pattern what caused it. If we can replicate it, ZAP R&D will be able to fix it pretty fast.
        Logs would be would be helpful as well. you can attach them in your reply here in the Attachments field (click Add File button) — use the “Reply” button instead of the fast reply to reveal the ‘Attachments’ feature.
