Multirun view is very small
Home Forums ZAPTEST Old Posts Multirun view is very small
  • This topic has 2 replies, 2 voices, and was last updated 9 years ago by Jack Smith.
  • #30872
    Jack Smith
      Hello ZAP,
      We’ve started to use the ZAPTEST Multirun feature and we’ve noticed the view of the PC which runs the test is very small, can we view it larger?
        Basically there are 3 ways to make the view larger:
        1. Move your mouse cursor to the boundaries of the view and just extend manually their position, just by moving them.
        2. If the connected device is a mobile device, go to Tools -> Viewers -> Mobile Viewer to open the specific device’s viewer by specifying its credentials.
        3. If this is a remote machine open it before executing the test on a different machine, or using any RDP utility.
        Please note, the reason why the views in Multirun appear small is to allow as many as possible machinesdevices to be connected simultaneously to the Multirun (So one connected machinedevice view will not open over another connected machinedevice view).
        #30874
        Jack Smith
          Thank you Sasha for the quick response.
