Multiple tests with same scan details
Home Forums Ask Expert Multiple tests with same scan details
  • This topic has 3 replies, 2 voices, and was last updated 3 years ago by Sasha ZAP.
  • #33144
    Alan Carr
      Is it possible to use the same scan / Repositry explorer for multiple tests. I plan to split my tests into simple small standalone tests then launch them separately via command line or similair
      #33147
        Hello a.carr,
        Basically you can copy your test and run the identical copies as required.
        Import a savedexported testsobject repositories can be done only in the ZAPTEST Enterprise Edition:
        Please contact ZAP to get the ZAPTEST Enterprise Edition (So you’ll be able to use ZAPTEST entire features) at:
        Contact
        Alan Carr
          So just to be clear if I scan my GUI and create a single test. There is no way of using the previously scanned repositry when creating a new test. so I would need to scan the same GUI again ?
          However this is available in the enterprise version ?
          So if I use the free version then all my tests would need to be through my steps from beginning to end ?
          #33149
            Hello a.carr,
            Yes, you are correct.
            Also in ZAPTEST Free Edition, if you’ll click on the upper-left menu File option, you’ll notice the Import and the Export options also contain the “(ZAPTEST Enterprise)” note:
            You can only importexport Datatable fromto ExcelCSV files’ types (And in these files you can use only its first 3 rows).
            In ZAPTEST Enterprise Edition you have no such limitations.
