Multiple Chrome Instances Problem
Home Forums Ask Expert Multiple Chrome Instances Problem
  • #32754
      Hello!
      If you use the Launch method to open a browser you should not have another instance of the same browser type.
      Please use different browser for the Tutorial if you want to keep it open.
      If you want ZAPTEST to distinguish between browser windows you need to dynamically set “regexpwndtitle” value in Application object (use page title).
      Note: this only works for different windows, not for different tabs on a same browser window.
