Modularity in ZAPTEST
- This topic has 0 replies, 1 voice, and was last updated 10 years, 5 months ago by
Home › Forums › ZAPTEST › Best Practices › Modularity in ZAPTEST
In software design, modularity refers to a logical partitioning of the "software design" that allows complex software to be manageable for the purpose of implementation and maintenance. The logic of partitioning may be based on related functions, implementation considerations, data links, or other criteria.
In ZAPTEST you can implement the modularity in the following way:
1) By using the TestParameters feature (With its different related methods) to adduseupdate parameters;
2) By using the Runtest feature you can call different test from within a specific test and send to it Parameters’ values;
3) Using the TestParameters and the Runtest you can create a modular test which will be simple to maintain, create and understand.
4) Using M-RUN to run the same test on different environments with unique parameters for each device
