Microsoft Edge datatable
Home Forums Ask Expert Microsoft Edge datatable
  • #31071
      Good morning, Effaezn88!
      Current version of ZAPTEST doesn’t have shortcut for launching edge browser. It means that after launching browser you should update “Application” properties. See my example how to launch edge browser:
      Application("Application").Launch "microsoft-edge:http://www.zaptest.com"
      Application("Application").SetProperty "regexpwndclass", "ApplicationFrameWindow"
      Application("Application").SetProperty "regexpwndtitle", "ZAPTEST"
      wait 3
      Application("Application").CaptureBitmap
      “ApplicationFrameWindow” is const. Your should update only “regexpwndtitle” option. Usually you could keep it empty.
      You could apply this example to your datatable. ZAPTEST Team will add shortcut for edge browser in future release.
      If Datatable.Value("browser") = "microsoft-edge" Then
      Application("Application").Launch Datatable.Value("browser") & ":http://" & Datatable.Value("url")
      Application("Application").SetProperty "regexpwndtitle", ""
      Else
      Application("Application").Launch Datatable.Value("browser"), Datatable.Value("url")
      End If
      wait 3
      Script is attached.
      Effa Nasa
        Hi AndreySh,
        I have try your code and its works. I also have update the zaptest and now can just simply using edge without added the code.
        But Im just curious why the result showing fails when im try to open in edge.
        Anyway thanks for your help. 🙂
        #31276
          Sorry for the long reply. This was fixed a couple month ago. Now you should use the same logic as for other browser’s.
          Application("Application").Launch "edge", "http://...your...url..."
