Method zapTypeText
Method zapTypeText
Home Forums ZAPTEST Old Posts Method zapTypeText
  • #30622
      The zapTypeText operation will type text into any object in the AUT.
      To type a text into a text-box, for example:
      1. Add an object to the repository.
      2. Select "Text" as the object class, type the Object Name, and select the position of the object.
      3. Save the object to the repository.
      4. Drag the object into the test case.
      5. Select the zapTypeText operation and enter the value for input.
      6. Run the test. As you can see, the text was typed into the object.
