Method Contains different from GetText
Home Forums Ask Expert Method Contains different from GetText
  • #32188
      Hello gabriel.fiel. Thanks for using ZAPTEST.
      I think VB Script function “replace” will help you! You need to replace possible spaces (” “) with null (“”) and then you can compare the content.
      Kirill.
      Gabriel Fiel
        Hi Kirill
        I am using javascript, so I tried Zap.Common.ReplaceSubString:
        var myVar= Zap.Common.ReplaceSubString(Application("My app").View("My View").Object("Text").GetText(), " ", "");
        if (myVar.Contains("20123.123")) {
        I also tried this one:
        var myVar = Application("My app").View("My Viiew").Object("Text").GetText();
        var newVar = myVar.replace(" ", "");
        if (newVar.Contains("20123.123")) {
        But it is not working, it shows an error when I try to use method Contains() with the variable (“O objeto não da suporte para a propriedade ou método”).
        Can you help me?
        Thank you.
        #32190
          Hey Gabriel
          First of all I have to admit that you are using GetText method improperly – to grab some text from the object you need to have real parent object for it otherwise ZAPTEST will not know where get text from and you will get empty value. And as soon as the value is null Contains method may output an error.
          Kirill.
          Gabriel Fiel
            It was an example of how I am using it.
            I am using .Object(“parent”).Object(“son”).GetText() in the script.
            I get the text from the object, it is there, working.
            The problem here is with method Contains(), because in the documentation they use it with an object: Object(“x”).Contains(“something”).
            I am trying to use a variable instead: myVariable.Contains(“something”), is there a similar solution to solve this?
            Thank you 🙂
            Bye
