Menu item selection – reused code
Home Forums Ask Expert Menu item selection – reused code
  • #43668
      Good morning Marco,
      Basically in your test in its first iteration the appeared site has a different UI view with a lot of blue objects in it but then the site in the second iteration has a UI which its objects’ color is mostly orange – Because of such UI differences ZAPTEST has difficulties to locate the object properly:
      You must add 2 Views in the Repository, one for the:
      https://labtcp.omoove.com/whitelabel/customer-base/login.html” site
      and one for the:
      https://labtcp.omoove.com/infomobilitypre/customer-base/login.html” site.
      Each iteration will use a different Repository View.
      The password does not work for me no more, but in your end please check if the Application’s object “regexpwndtitle” property changes after login to the site, if yes then you must add als new Application objects (And all their related Views) for each of the different URLs sites.
        Thanks Sasha
        The “regexpwndtitle” property does not change as the endpoint changes.
        Too bad I can’t reuse the code and views for both endpoints.
        I’ll have to keep two views instead of one.
        Thanks anyway
