MacBook Automation
MacBook Automation
Home Forums Ask Expert MacBook Automation
  • #59509
    Dominique Gisquière
      Dear,
      I want to automate some web testing on Safari on my MacBook.
      I had a look at the doc, but I cannot find the way to connect my Mac to my Win 11 PC in the doc.
      Can you give the link to this topic?
      Cheers!
      #59787
        Hello Dominique,
        ZAPTEST can be installed only on a MS Windows based OS, but by using its different remote connection options you can set ZAPTEST to test and run any type of environment, OS, app, etc.
        One of ZAPTEST main remote connection features is the M-RUN, please check the following tutorial video how to use M-RUN to connect to any remote device and set it for ZAPTEST:
        M-RUN
        Regarding the Mac OSX the video demonstrates how to execute in it Firefox, but you can set any type of Browserapp to be executed in it.
